1 - 20 of 35 Posts
· Banned
So after reading up on it and doing a ton of research, tomorrow my versa is going under the knife. I am using a short block from the mr20 and retaining my top end and all. The heads are the same, timing components, tranny basically everythiing but the block, crank and pistons. I will get some pics as we go. Should be all complete by end of day friday. Can't wait
goodluck! any reason you didn't source a longblock?
· Banned
Question if your going throw the time and money for a mr20 swap...why not do the qr? If the mr20 mounts right in I wouldn't see why the qr wouldn't? Only issue I can think of would be the tranny?
Sent from my DROID2 using Tapatalk
QR has a different tranny, and different ECU and other things just can't think of them right now. MR20 is just a simple swap.
awesome cant wait for it...take lots of pictures!!
Interesting... If I ever make it out to a meet I hope you are there so I can take a look at it! This is something I have wondered about doing.
· Banned
Discussion Starter · #10 ·
Like i said fortunately for me i work in a dealer. The cost of a used long block and a new short block were so close i decided to go this route. I will take as many pics as i can. Work starts in a couple hours, engine will be here this afternoon. I am quite excited of course
your going to get a CEL for the first week or two, its an idle code. your RPMs will be between 1,200-2,000 at idle. the ecu has to get used to the new engine even if you clear the code itll come back so give it some time. if you run into that situation, what i did was drive it for a week, clear the code (itll turn back on after several miles driven), Then drive it another week and clear the code then it actually goes away and your RPMs will go back to like 800 or whatever the car idles at normally :thumb2:
· Banned
Discussion Starter · #12 ·
We will see soon. Lol. I don't know if mine will react differently as I'm not changing anything but the block. My 09 has different coils than the 07 has. They are the same as sentra. But time will tell. She's on her way out now. Short block is here
· Banned
Discussion Starter · #14 ·
Did you have your idle relearned at a dealer? It really sounds like you didn't. There is no reason the idle should be messed up at all besides that. If you used the throttle body off the 2.0 you would have needed it
car has to learn to adapt to the 2 from the 1.8. I got a whole 2.0 engine throttle body and everything. the ecu just has to adapt, its no big deal
Nice! Can't wait to hear the results of this. I am pretty interested in hearing about the fuel economy, how it does/doesn't differ from the MR18DE. I know yes it is a bigger displacement, but the MR18DE is not the most fuel efficient 1.8 around.
· Banned
Discussion Starter · #20 ·
Little snag this afternoon. It was pretty busy so we didn't get everything finished. Engine is in. Just the axles and exhaust and fluids. It'll be out tomorrow. I have tons of pics I'll post up when I have some time
1 - 20 of 35 Posts
