Hello. I got a brand new 11 versa sl fully loaded a month ago. I will idle for 10 to 20 minutes usually because I like to get to work early. I noticed after idling for a few minutes, the ac will turn off. The compressor itself doesn't work. I will turn the ac compressor button on off and nothing happens. The ac light is on so I know the compressor should be on. The rpm doesn't change. Once I start driving, it will kick in again and I hear the compressor engage/ I took it to nissan and they replaced I believe the temp sensor, inside the dash. The problem continues. Now when I am idle for 20 minutes or so, the high temp light comes on. I also noticed the ac isn't that cool. Anyone notice that? I am taking it back to nissan tomorrow for someone else to look at it. It is quite frustrating. I am concerned about the overheating, I had a titan before this and never had any issue idling. Could the ac and the overheating be linked? Also the compressor is quite loud, is this normal? Thanks for the help.
I also got a remote starter installed but I don't see how this could have any issue with overheating or the ac.
