New guy with a question
2170 Views 5 Replies 5 Participants Last post by  scwinn
I just recently purchased a 2012 Versa, It is an S model. I was just wondering if anyone knew how to get it to go into program mode for the keyless entry. It did not come with keyless remotes. I have searched all over and not found out how to get it to work if it does not flash the hazard lights while trying to program them. I've compared the fuses and box behind the glovebox to my friends versa, who has keyless, and they seem the same. Thanks for any help and sorry for the long winded first post...
First off are you sure it has the receiver for the keyless entry.
Most likely if it did not come w keyless entry remotes, you'll need to install most if not all of the system.
It does have the little black box behind the glovebox, with a 3 wire connector just to the left. I read on another thread that is supposedly the keyless box or brain.
I don't think key less was even an option on S trim. I have S trim and there are no solenoids on the door. I took off door panel to see if I have enough room to install universal power door lock kit and did not see enything there .
discussion
There is no keyless entry in S trim.
