New member here with a situation
1163 Views 1 Reply 2 Participants Last post by  Note-ified
I have a 2013 nissan versa sedan. Decided to upgrade the rear brake light bulbs and reverse bulbs to LED bulbs. Now the car will not go over 10 mph with the lights on. I turn them off and it's fine. What's the cause of this ??
wrong section to post this, but to try and answer your question it sounds like the bulbs you are using are causing a short somewhere in the electrical system so my advice would be to take them out and see if the problem still persists, if it does then one of two things happened, you blew a fuse or possibly there is some other underlying problem with the car that just happened to happen at the same time you switched the bulbs. best to start off with the removing the bulbs first though to start your troubleshooting.
