Hello all,
I am glad I found this forum. I am a new member and I have an A.C. issue with my wife's 07 Versa hatchback.
When it's hot and I am driving, I would turn the AC on at 4 and put it to very cold. The AC blow normally from the front blowers. After about fifteen minutes or so, the blower pressure would decrease to as if I had it on a 1 setting or lower. After messing around with it for a bit, I found that if I turn the heat on for five minutes, then turn on the air after, it will continue to blow on 4 again, for five minutes, and then decrease to like a 1, and so on and so on.
I am not a mechanic or anything like that, but it seems as if the pipes or something is freezing over, and I lose pressure, because if I turn on the heat, it never decreases in power.
I am assuming some type of thermostat is broken or something?
Any help will be much appreciated... Thank you all with my first post!
