Hi everyone,
I have a question and hope you all can help me out. Me and my wife are the proud owners of a 2007 Tiida 2wd. Both front wheel bearing hubs needs to be replaced but we can't get the right sets we need for the sc11. The lug patterns are 4x100 and every auto parts store we go to only have the wider lug pattern part which appears to be 4x114.5. We literally can't get the part in my country so we are wondering if we can go ahead and buy the 4x114.5 wheel bearing hubs and use it since it is more available. We know that we would have to change the rotor disc and rims to match the new 4x114.5 hubs but we aren't really sure if it will fit the spindle /axle. Also is the only difference between the two types of wheel bearing hubs are the bolt pattern diameter?
What market was the car made for? I'm pretty sure all hubs were 4x114. Did you measure the bolt circle yourself and that's how you came to the conclusion? Already tried a hub from the parts store and discovered it wasn't the same? Also what grounds do you have for replacing both? Is it that you are getting a growling noise or is there play evident on both sides?
3 Participants
07Versa6MT
