Hey guys, I want to upgrade my 2010 Versa S sedan radio to an OEM one that has MP3 playback. Pretty much what the SL model comes with. Can someone tell me if any of these listed below will work.
My faceplate says CY17F
I see many different faceplates from other Nissan vehicles. Will any of them work?
This I saw on Nissan Versa, SL model <CY11F>
This I saw on Nissan Sentra <CY13F>
This I saw on Nissan Cube <CY26G>
Thanks
People have upgraded to versa sl radios before. The other ones I can't say will or won't work.
Thanks
Truly there are replacement parts distributed in some Nissan series. Some would work and some would not. Why not take a look at the service bulletin from the dealer? It's them who have further knowledge about your prob. Anyway, there are lots of replacement nissan parts you can have online and most of them are discounted..
I dont know about all this. I had an S sedan, and I bought an SL radio, and when I called Nissan to know what numbers were compatible with mine, it was a joke. The radio that was in my car from Nissan, didnt even match the numbers they told me on the phone. From that point on, I knew they were a joke. The SL radio worked fine in my car. The radio even worked in the sentra. I can tell you right now that the 07-09 nissan versa, sentra, and cube have the same radios. Since 2010 almost all Nissan's are using the same radios except maxima, armada, 370z, murano, I believe. Nissan has switch out to using the square radio in every car. I can tell you the sentra, versa, cube, rogue, and juke use the same navagition system. Just like maxima, murano, titan, pathfinder, quest, and armada use the same navation interface system. I would just compare the main harness plug. Ill say this, any radio from versa, sentra, cube, and juke you find, im 99.9% sure it will work. Dont listen to the dealer, they dont know.
OK but when I was looking at the SL radio's they have more plug areas then what came with the S, can you take a picture of the SL radio you have connected to your versa?
