The other night as I left my in-laws, they called me o let me know I had no parking lamps, which after a quick check at home, also uncovered I had no tail lamps either.
Headlamps work, brake lamps work, just no tail or parkers. So I did some hunting and finally found the fuse box for them (dodgy little panel under the bonnet that looks like acabin filter insert
) and replaced the burnt fuse.
That blew immediately when I turned the parkers on, so I then decided to pull out every tail and parker globe in the system and test it again, which alas, blew a fuse again
So now I gotta get Nissan to look at it, because in the full service manual there's a big row of instructions on how to chase down the culprit, so I feel they can do it instead
Let you know how it goes
