Maybe just needs some preventative maintenance
My 07 has approx 57,000 miles and the front brakes were making some noise when backing out of the driveway.
Last month, I removed the caliper pins and pulled the pads. I estimate they had another 25,000 miles of wear left, which is quite impressive. The pins were almost dry with some moisture contamination, and there was no lube left on the back of the pads where they contact the piston. I took some high quality brake lube and put some on the back of the pads and on the caliper pins. Fixed the problem. :thumb2:
