Ok so whenever i start my car on morning, i get this squeaky sound for few seconds, like '1 second' and then it goes away.
Is it serpentine belt issue? Big problem?
Mine serpentine belt is like 2 years 6 months old.
It usually happens when i start the car the first time, and usually on mornings..
However, yesterday afternoon, i wanted to see what happens if i leave key in the ignition position after car starts (for fun sake). This time it was afternoon, car was warm, i had driven it 30 mins ago. That same noise was there, until i released the key from ignition.
Which got me confused, is it starter issue or belt issue?
All my ignitions are otherwise normal with no playing around with ignition position.
Could be a belt starting to slip. Remember it goes from static to torque pretty instantaneously. Is your A/C on for startup by any chance? Or is it on windsheild defrost? I know the compressor in my Versa was noisy as hell when it started up.
I doubt it's the belt, but 2 years warrants a replacement anyways, it's cheap and easy to do. Check out the condition. Get a flashlight down in there and check the ribbed side for cracked ribs, loose fibers, chafed edges. If the flat side is shiny, that is grounds for replacement iregardless.
You'd get a faster diagnosis if you posted a clip or video of said noise. I can't tell what you're talking about, there's many noises at startup that are normal. I assume you mean that you kept the key in the "start/crank" position and the noise persisted? The noise that would produce would be a very clear screeching, just a bad sound to anyone. That would be the starter pinion clashing with the ring gear. It's possible that the flywheel/flexplate ring gear has some "dead spots" in it, meaning worn, chewed up or missing teeth.
