41 - 48 of 48 Posts
How did you guys go about getting your headers installed? As far as doing it yourself or getting it installed at a shop. Also if you installed it yourself what kind of problems did you have and how did you deal with those problems?
Just installed these headers last week, so I figure ill update this thread.
First things first, its a real PITA to do by yourself in the garage, but yeah its do-able.
Main problem I had was the fitment of the rear O2 sensor. When I snugged the bolts on the header/testpipe flange the wires on the sensor hit the heat shield. Tightening the bolts made it worse. I had to take off the heat shield entirely to torque the bolts all the way..
Fitment with the stock resonator was off too. It lifts the resonator up and causes it to hit the heat shield and thus sounding like horse shit.
(Oh and you will need to buy two 3/8x16 bolts to thread into the test pipe. For some stupid reason they don't include them, and none of the stock bolts will thread in.)
I managed to tweak the exhaust for the time being to not hit anything, but I'm going to weld a new exhaust from the test pipe back to get things sorted permanently.
Check engine light came on after 50 miles (removed cats), I switched from 87 to 89 octane and the code cleared itself and has been off since.
As far as power gains, its all mid range and top end. 3rd defiantly pulls harder and it moves quicker through the 5-6k rpm range in all gears.
I can't comment on sound to much right now as the only thing muffling it is the one stock resonator. Much too loud when you step on it... Like stupid loud. Hilarious really. I should really make a video so you all can get a good laugh before I weld on the rest of the exhaust.
Right, so how does switching octane make a cat efficiency code go away pray tell? Tell me your theory!
Also in a less condescending, more serious tone, what did you notice for gains? Entire range? Response?
lol tbh it was more of an observation. I'm not entirely sure how the secondary O2 sensor determines when to throw a code or not. I based my statement off my experience of switching fuels then having the code clear on the way home. In this case it could be any number of untested hypotheses :)
Power wise, low range seems unchanged. But lets say I do a WOT pull for 2nd and 3rd. At about 3.5-4k in second you can feel the torque difference and it will stay constant to red line. Shift to 3rd and the torque will keep pulling and the car gets moving pretty good. 4th is healthy as well but I wont rev it out that far on public roads...
Response in 6th at freeway speed (~70mph) is improved, but I still downshift to 5th if I want to pass quicker.
When downshifting, the revs pick up a little faster, but I think the light weight flywheel would make more of a difference.
Post cat sensor is a conventional narrow band sensor which sees the lean/rich sine wave, except the exhaust composition after the cat will be closer to stoich, so really it's monitoring that sensor for a very minimal swing (lean to rich) since the cat uses oxygen to oxidize the hydrocarbons from rich swings, causing the downstream composition to have less oxygen than the pre-cat mixture. Combine this with programmed values in ECM for the maximum post cat lean/rich variation and you get a code if the sensor feedback is over the threshold. After removing the cats, the sensor sees a switching singal that is too great because there is no post treatment.
Hey guys. So I have a 2008 Nissan versa sedan and I'm wanting to put the obx header and exhaust on it but I was wondering if someone could send me the link where I can buy it at. I have already been burnt once when buy a header. So just looking for a little help on where I can get the parts at. Thank you
41 - 48 of 48 Posts
