You're most likely looking at disassembling the cluster and either swapping the display section out from a newer model (my 15 sedan had the same cluster but the text on the display was white) OR there may just be an overlay film that you can peel off. Some of the older GM products with a similar display had a pink film over a green display to turn the text white. Nissan may have used something similar.
