G
I salvaged a OEM fosgate sub box amp harness and all out of a totaled versa and I got it bolted in but not sure on how to wire it or where to wire it in help please
If your didn't already have the upgraded sound system you will not be pre-wired for the sub. Do you have an aftermarket headunit or the stock one? the SL unit uses different wiring harnesses than the S. I'm not sure if you'll be able to wire it in without those harnesses.
G
yeah its stock I may just hold off on it until I go to put a new head unit in
