it could be a malfunctioning oil pressure sensor.
Its 65FOA for a Versa right?Could just be a crappy oil filter. Just make sure your oil level is adequate and that's all you really can do at this point. I wouldn't attempt to swap sensors or anything yet. You might want to check to make sure you have no dents in your oil pan too.
Next oil change use the appropriate weight oil (5w-30) and a quality filter. I suggest purolator pure one.
Yes that is the correct number for the oil filter. Price is about the same for purolator pure one and dealer. Both about $7. I like the pure one because it got great reviews online and supposedly nissan started to cheap out on their construction a few years back. Plus it has a textured coating that makes installation and removal of the filter super easy. My hand slips on the smooth filters and I prefer not to use a tool when installing. That way I don't over tighten it.Its 65FOA for a Versa right?
How much would be the the cost difference between an OEM filter and purolator pure one filter?
Im going for an early service this time (thursday most likely).. to avoid any sort of damage
