I went to a shop today and they told me my battery is going to die and I am planning to order the Optima Yellow Top battery. My car has a AT transmission and all the search results from different part websites gave me the battery model for CVT. Does anyone know the part number of the Optima Yellow Top battery for the AT? Thank you in advance.:thumbsup:
Are you sure that will fit? I went to a battery place and they said it wouldn't. 17 lb Bosch 51r450b from PepBoys which i was told is a direct fit replacement. Check it out and let us know!
Also, i did look up the Optima battery. It is a direct fit but weighing in at 27lbs. Unless you are running an upgraded stereo system, save the money and the weight and go with the Bosch battery at 17lbs. The 9lbs braille battery has enough cranking amps for the Versa small normally aspirated engine. Priced at 150 and comes with the bracket from tire rack. Just some other options to consider.
