Interesting, where did you route the outside sensor for the temperature?
The two wires from the unit poke under the panel that's above the instruments. The power went to the 12V outlets that I have above the radio and the sensor wire I routed above the pedals and then beneath the door seal which I pulled away from the body. The wire is small enough for it to sit under the door seal quite happily. The sensor then just sticks to the bodywork in the door jamb.Interesting, where did you route the outside sensor for the temperature?
I tried it in all sorts of places but it was always at the wrong angle to actually be able to read the display. Took me a few days to notice that I could stick it where I did and I'm actually quite pleased with it - doesn't get in the way of the instruments at all for me.I want one of these to replace my wal-mart thermometer.. I'm not sure about the placement though, I might try other locations first. It's little mods like this that I enjoy the most![]()
That's how I was at first. When I found out I needed to drill a hole for my amp wire I almost FREAKEDI only do little mods as I'm frightened of doing big ones.....
