1 - 12 of 12 Posts
Hi, I need a some help with my problem. (P2097- Post Catalytic Fuel Trim System Too Rich Bank1)
I try to change a few stuff:
SPark plugs OEM
Oxygen sensor NTK
OEM air filter
PCV valve
I delete a code and after 50 miles car start shacking for while( i change a gear transmision positon to N ) and
car stop. After anoter 15 miles check engine show up with same code.
Do you have any suggestion what can be worth to check or change?
also i checked harness, check poor electrical connection ,Intake air leaks and Exhaust leaks
:surprise:frown:frown
Discussion Starter #4
Thank you for reply. second
o2 have a different code and cat too. Can i asked what is MAF? and how i can check hi presser fuel? THX
Discussion Starter #7
nothing working....
I try everything. i think so.
sombody can help me with this?? I need good profiesonalit in NJ?
thanks for any good advise
I sent you a private message with the name, address, and telephone number of a good shop in New Jersey that does quality work at fair prices.
Discussion Starter #9
Okey, Finally I change a Dealer and find to right person.
My problem it was a old Software. Any equipment and parts was bad.
Stupid soft??!?
Car start working much more smooth and better. AVG. Used Gas goes up to 35 mpg
So so far I am happy. Don't go to far to replaced any parts find first a reason!!
[QUOTE = "DULINA1983, должность: 287104, участник: 60906"]
Окей, наконец я меняю дилера и нахожу нужного человека.
Моей проблемой было старое ПО. Любое оборудование и запчасти были плохими.
Тупой мягкий ??!?
Машина начала работать намного ровнее и качественнее. AVG. Используемый газ идет до 35 миль на галлон
Так что пока я счастлив. Не уходите далеко, чтобы заменить какие-либо детали, сначала найдите причину!
[/ QUOTE]
Дорогой друг. Я очистил топливную систему и появилась ошибка P2096, после замены датчика O2 появилась ошибка P2097. скажите, какое программное обеспечение было изменено?
Dear friend. I cleaned the fuel system and error P2096 appeared, after replacing the O2 sensor, error P2097 appeared. tell me what kind of software has been changed?
1 - 12 of 12 Posts
