The factory hu was shot, shot bought a cheap dual double din touchscreen from Walmart. Hooked up the new harness and radio adapter but getting a no signal most of the time. Sometimes it works fine for awhile but eventually the screen turns black with a no signal reading. I have the one ground capped (says for Subaru only) the amp on capped, and reverse capped. I ran the one ground to the original bracket that I kept. Can anybody please help me out, thank you everybody
18334
First, the antenna wire does NOT get connected to the main harness.
Most Nissan radios are self grounding. you may need to run a wire to one of the ground points.
If you search in the I.C.E. section, I have a few posts with wiring diagrams, wire colors, and descriptions for the 20 pin main harness.
  • Like
Reactions: pimperell
