Those pictures don't tell me anything. Your connectors on the headlights don't look like they will connect to the OEM harness. Unless you have a diagram of the wires and what they go to, how can we help you? It's hard to play electrician over the internet.
LOL you made me post after so many months of not posting :O
First after looking at the image it looks like you don't have a ballast! Those black and yellow connector connects to a ballast. THen you connect the ballast to the OEM connector. Does your kit come with a ballast?
nope, you need the ballasts or the whole assembly won't work. if you can't get the ballast you'll have to buy a pair (if they sell just ballasts) or buy a new HID assembly, ddmtuning has cheap ones that work great and are small, still rockn mine after a year
nice tango yo when are we meeting up again?
@clean you can get those ballast for only 20 bucks or less i think google ddmtuning hmm wait http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W here check that out its pretty cheap hmmm as tango said you can remove those and put in a regular bulb but you need to fix the rubber enclosure because it looks like it got pierced through. I wouldn't recommend running these on regular bulb even on a high output bulb i tried regular and xenon type both sucks HID is the only way to go.
1 - 16 of 16 Posts
