I just took my headlights out yesterday so I can tell you exactly how!
Ok once you got your grill off your going to need to take the top bolts off of the headlight. There are 3 10mm bolts along the top on each headlight.
Once you are done with that you will need to take apart the clips that hold in your wheel well so that you can peel your bumper back a little bit (which is also being held in by a 10mm bolt). Once thats done you will see one (1) more 10mm bolt that is literally almost against your bumper. Once you take out that bolt, wiggle the headlight around and kind of push it backwards because it is also "clipped" into your bumper.
I wish I would have taken pictures so it would be easier for you but I didnt.. I'm on here a lot so if you have any troubles just post it and I will help you out.
Good luck!
Don't Forget to post some pictures!
WELCOME TO THE FORUMS!
