Radio Display Fades when hot
1013 Views 3 Replies 4 Participants Last post by  ted939
I have a 2015 Versa Note with 54k on it. The radio display virtually disappears in hot weather. Apparently this is a very common problem with the Nissan radios. I found a UK Company (Minitools) that will sell a replacement display for about $116. Anybody have any experience with this company or have any other solutions?
Denny Fegan
Bacliff TX
  • Like
Reactions: 1
You are probably better off with aftermarket.
  • Like
Reactions: 1
yes i agree...except for the time..i do not even use mine..set up your presets..then you do not have to see the display
I have the same problem with my 2015 Versa Note SV, pretty much since I bought it used in 2016.
Doesn't matter if it's bright or dark out, it depends on the weather. Hot weather makes the radio display dim, sometimes to completely nothing showing.
Recently, the unit just stopped working completely. Then, a couple or few days later, it started working again.
I wonder if all that is related to this electrical issue my car has:
My car has an electrical leak for the last year or two. I've had the battery, alternator and starter all tested, and mechanic says they're great.
If I turn off the car, but continue listening to the radio for a couple minutes (not high draw amplification, just some interview on the radio), car won't start.
If I leave headlights on for 30 seconds after turning off car, car won't start. Then I jump start my car with another car or a battery pack jumper cable, and it starts right up.
This might happen a couple or few days in a row, and then no problem at all for a few days or even several weeks.
A tech recently put an ac/dc clamp meter around my battery cable, and saw that 1.3A was flowing through it, with ALL lights, switches, fans, radio, etc turned off.
Anyone know any solution to all this?
Thanks!
Ted
