Hi,
I hope that someone can help me understand this strange situation. I tough that i could do i radio Swap of the basic factory radio to the one with the Nissan factory radio but with the 5 inches screen.
Since my 2014 versa did not have a backup camera, it did not bother me not to have it a the new radio unit, but i said to myself that it would be nice to have a little upgrade of my radio Unit. So i swapped the radio and found out that one of the cable could not be attached to the new radio, I tough, oh well , i will just see what`s working so i gave it a try. I've turned on the the ignition to on. The radio came alive, every thing looks ok, but i quickly realized that the SOURCE,SELECT and VOLUME buttons on the steering wheel were not working. I tough it might be the cable that i did not plugged. So after a few minutes of verification i've decided to put back the original radio in place. To my surprise the SOURCE, SELECT and VOLUME buttons were not working either...
Is there some thing i can verify to make them work again? Could it be related to the new radio and some kind of a mismatched pin connection and when i plugged it and blew the steering wheel button module. I did not touched anything else. Call button Phone to Bluetooth radio is working.
Thank you in advance for your answers. :crying:
Discussion Starter · #2 ·
Update:
Finally i had to bring the car to the Nissan repair service. They had to change the left steering wheel module (The one with the buttons that were not working).
Since i have an extended warranty for my Versa, i was not charged for the replacement. On the other side i'm not sure that they had to change the module. For some reason i had to pickup my car to go back to home because they did not have the part in stock and there was another fix to be done on my car so they asked me to come back the next morning. To my surprise all the buttons were working well. When i brought back my car the next day i said to the service manager that everything was back to normal. My assumption is, that they unplugged the cable attached to the module or the radio, put it back on and reset the connection. Other option, is that they unplugged the wire from the battery and by reattaching it, it reset the module. I'm not an expert but i think it could have an effect on resolving the problem. Because the part was under warranty the manager decided to replace it just to avoid any other problem.
Thank you for this information..I just had the same issue with my 2016 Versa after attempting to install a Sentra video display unit. I pulled my battery and BT module and let it sit for 5 mins.. plugged it back in and connected the battery and everything was working as stock again! Whew... I will do some more reading before trying this again.
Update:
