Have a friend drive the car and while it is making this "rattle" sound push on various items around the that area and see if you can change the sound or eliminate it. Once you locate where the sound is coming from insert felt stick on disc between the two offending parts.
I suspect two pieces of plastic have deformed slightly and are rubbing. They just need a little buffer between them.
My girlfriend's Dodge had a similar problem (in a defrost vent), once I located the two offending pieces of plastic, I went to Dollar Tree got some stick on felt discs and fixed the issue for $1.25.
