Guys I replaced my wheel bearing about two weeks ago and I broke the ABS sensor. Long story short is I installed a bearing that was non-abs and I didn't remove the plate. So this plate actually cut the abs sensor.
Lesson: REMOVE YOUR ABS SENSOR BEFORE INSTALLING FRONT WHEEL BEARING. However this isn't the reason why you should read this before buying an ABS harness.
I went to Nissan to get a quote and they wanted $230.00! So Napa it is and they wanted $83.00 which is much more reasonable. I figured it was an after market part and decided to go for it.
It turns out it is IDENTICAL with the only difference in price. The brand that makes this harness is Bosch and was branded on both the new and old harness. Before purchasing OEM check out another supplier as this saved me $147.00.
Cheers
Cheers
