I know Bob did the rear disc brake conversion. Will the Rotora Big Brake kit work on the rear?
Hey Soros, welcome to the forums.
Yes I believe he used a Sentra setup, there is a thread on here somewhere with details. Lemme see if I can find it.....
*edit* here ya go: http://www.nissanversaforums.com/showthread.php?p=6608&highlight=rear+disc#post6608
I know this is usually a beat to death topic however i just realized that more often than not, the discs would be cracked from time to time but i know there are discs that possessed quality and durability and most of them can be found on reputable online stores..Thanks for the Welcome, I'm just trying to learn what others are doing. The only way I see a rear brake setup is worth doing would be to reduce Un-Sprung Weight, but Calipers from the Sentra I believe are Cast Iron, which might weight more than the drum setup. I started reseraching around and even if it's an old school trick, this might work. >> Classic Trucksbrake disc This might just be an idea. Sounds good enough for me. Again, thanks for the welcome.
