2007 Versa s hatch 6spd
Today I went ahead and installed my jbl club 6520 speakers in the Versa. Overall this was pretty easy, but during the install I noted the factory rear driver side speaker was not working. I was hoping this was simply a bad speaker but after installing the new speaker it is still not working. I will be trying the port cleaning I read about from other people but I wanted to check and see if this is a known issue or there are any other recommendations for trying to get it working. I used plug adapters and I plan on cutting the ends and splicing if they do not work.
even with just the three functioning the sound with my Sony headunit is so much better. I can get above 20 on the dial without everything turning to gargle. These speakers are a pretty good deal on Amazon right now if anyone is looking for a cheap upgrade.
Anything is an improvement over the base speakers.
As for the wiring, pull the wires out of the connector and clean really good. If still not working, check the door harness connector, etc.
  • Like
Reactions: pimperell
