Just changed my rear shocks on my 2007 Versa SL. Following the manual it says to remove the rear tires and sensor. I didn't, I jacked the car up and placed it on jack stands. Then used the jack to remove a little tension on the shock. Loosened the upper mounting bolt, then the lower mounting bolt. Then installed the new shocks. Made it a 20min job. Very easy
