1 - 14 of 14 Posts
Hi Guys I'm new in this forum and I need some help with mi V. I bought the basic 1.8S sedan without power options. I want to make it power lock, just for the convenience. I bought in eBay a generic remote power lock system but when I open the door panel, looks like the car already have the actuator and just need the wiring. Did any one know how to make the conections? if I need to buy another swith just to open / close all door manualy? if I can use the aftermarket remote receiver?
I really appreciate any help...thank you guys..
You could prolly get the nissan OEM power lock switch off of ebay, and the wiring harness for the door, and it would prolly hook right up. But this is my two cents, I really dont know, but it is what I would try and do. So far everything ive done to the versa, has been plug and play, or already prewired. So check around the door to see if maybe you already have the wire harness and its just tied up somewhere in the door. I have a good feeling my suggesstion would work. I dont think there is a fuse for it. It should be tied into the fuse box located right underneath ur dimmer switch in the fuse called ELEC PARTS, but thats my opinion as well. Hope any of this info helps....
Wiring harness for door: http://www.courtesyparts.com/versa-...trical/240-wiring/-c-7153_7154_7187_7188.html
I woud assume there would be continuous power. When you remove ur drivers kick panel on the bottom left corner, you will see a bunch of wires (or that could be because I had a remote start put in, lol), or a big black cord , and somewhere around there I believe there is a white plastic connector with some wires running in it. Thats a start. But I would first take a look at ur setup, and decide what to start doing.
I used to be from MD. I was born in annapolis, moved to Glen burnie. My dads from Baltimore. We moved to NC about 5yrs ago.
Im planning on some vacation time in September, and had plans to drive up to MD again for family, and see some things. Maybe we can have a meet while im up there. I would love to talk with some of you guys, and take some pics, maybe.
Curious
After reading this thread i am very curious. I bought a 2010 versa 1.8s without power mostly because there were none left that had power and weren't fully loaded with everything else i didnt care about. I am pretty annoyed with the 1 lock on the drivers side myself and wish that they had at least if not power remote locks made it power locks so all the doors opened with the key or maybe by unlocking 2x with the key.
However i am curious if anyone can actually verify do the cars actually come with the power actuators in the doors? It would make sence to me that they are installed all along from the factory and then they simply dont put in the harness.
Anyone in the SE MA area thats good with theses cars and maybe has done this already?
YES all the Versa's have the actuators in the door/lock mechanism. The front doors are your standard 3 wire and the 2 rear doors are reverse polarity.
I simply had my Viper alarm hooked to the existing the lock actuators. Simple and easy
Excellent thank you for the info on that. I will probably invest in a car alarm after all so we can get remote lock and unlock (and a little savings on the insurance never hurts) I will give the installer this info also so they know ahead of time what they are looking at for the type of locks.
Again thank you so much. Good information is so hard to come by these days.
Just came back from the alarm installer seems there has been a change my versa did not even have the lock actuators in the door. They said the wiring harness is there but missing some wires and the actuators themself are not there at all. Kind of a bummer i had hoped to be able to get a alarm installed and have remote locks. Only other real option is to get a door lock kit from JCW but i am not really feeling like going through all that bother.
1 - 14 of 14 Posts
