TexasMade89 said:
It's not tape up front, it's a clip. You are correct about the pulling straight back though. Any other direction and for sure, SNAP. Lemme see if i can find this pic....In the hatch, theres two little plastic panels for each light. Remove the panels and youll have to remove the 10mm nuts from each stud thing. Kindof a tight fit. Once removed, youll want to pull the taillights straight back. Theres a little square of double sided tape i believe, on the forward most part of the light, on the side of the car. Try wiggling the light around if its stuck, or GENTLY try prying the tape free of the car. Not hard at all
