I m replacing the slave cylinder on a 2009 versa 5 spd. Im not sure how to remove the clips that hold the shifter cables to the transmission. Can anyone help?
Removing clip holding shifter cables to transmission
Looks like a hinge in middle, you can see the rivet that is the axle of it. Likely you remove bottom white end clip ring and then swing the hinge wide to unlock things.
See Step 3. Easiest to remove the linkage right at the transmission, instead of trying to undo the clips you're working with. This way the shift cable length also won't be affected as you disassemble and reassemble.
Yes, undo the clip and you lose cable adjustment, it then has to be done over. But sometimes that can be what you want.
He shows the correct way.
Related Threads
posts
123K
members
24K
Since
2008
