Looking for some help and if I can help anyone else please let me know, I’m replacing my head gasket and doing all the work myself so my question is can anyone recommend a good quality gasket kit I’m replacing all the gaskets since I now have everything apart.
I would go with the original parts, especially if your engine has many miles.
there is one kit on ebay with all the gaskets you need.
here
this is if you want to replace all gaskets, if not you can buy separate the ones that are most needed and save a few bucks.
was it giving you any issues? or did you do it just out of maintenance?
Discussion Starter · #4 ·
I would go with the original parts, especially if your engine has many miles. there is one kit on ebay with all the gaskets you need. here this is if you want to replace all gaskets, if not you can buy separate the ones that are most needed and save a few bucks. was it giving you any issues? or did you do it just out of maintenance?
Car over heated due to a crack in radiator, took the block in had it resurfaced since I have everything out I figured if replace all the gaskets. Thank you for your feedback much appreciated 👍🏽
