1 - 13 of 13 Posts
Only thing done to the car is aftermarket head unit, but it is a touchscreen dvd player and all. Everything online wants me to wire a certain wire to the parking brake but i haven't bothered to do that, so the dvds wont play. But I don't know if the lights were an issue before I installed that or not. I've checked one of the bulbs its fine, but I get no reaction when the car is put in reverse. It is a 6sp MT but I can't find any fuses or anything wrong. I also checked the reverse switch on the trans. Any ideas?
Connect DVD to parking brake? almost sounds like it would like you play unless it knows the car is not moving
Its so people aren't distracted watching DVDs while driving.
If I'm guessing what u are trying to do is that for u to be able to paly dvds ur ebrake needs to be one but I have that same setup but the trick if you want to be able to play dvds while ur driving is to hook the cable that goes to ur ebrake to the ground wire of the headunit and it should work. But y the lights won't turn on in the back idk
hi how did u fix this problem have the same problem....:confused:
1 - 13 of 13 Posts
