I have a 2008 Nissan Versa/Tiida Sedan and currently having this problem.
When the vehicle gear is engaged (D/2/1), the right turn signal lights shuts off and get stuck at OFF even I put the gear on NEUTRAL. Left turn signal works ok. On Hazard switched ON, same issue occurs as the right turn signal. To make it work again, I need to put it on Neutral, switch off turn signal lever (middle position) then switch on Turn signal again.
Been poking around the connectors/connection (cleaning with WD40) and I could not find and get this thing fixed.
In order for me to make it work while driving and turning right. Is to put the gear on Neutral, turn the right signal and going corners slowly.
Maybe someone had fixed the same issue here.
