Sentra Short Ram Intake on Versa?
3024 Views 5 Replies 4 Participants Last post by  #1Tango
Since the Sentra and the Versa use very similar engines and similarly sized engine bays, would it be possible to install a short-ram intake designed for the Sentra on the Versa? What model year Sentra is most comparable? There seem to be a wider variety of short ram intakes available for the Sentra and at better prices than the ones for the Versa.
Also, Amazon has an AEM short ram intake for Hondas that is $88 with free (prime) shipping...wishing they had something that cheap (and brand name) that would fit the V...sigh.
It should fit...you want a intake for a 2007+ sentra. B16 is the car model. Again both mr are pretty much the same givin a few odds and ends..meaning internals, etc. But for the most part external parts like headers, intake are the same...may need little modding to fit not sure though. But the maf should match up. I believe on guy with a mr20 swap used his versa intake for it.. so u should be fine....make sure its for a 2.0 though...the ser or spec v maf slot will not work. I found this out the hard way with my old 2.0...weapon r is probably the most common one but there is more just have to look. Ill look around my sentra fourms for u if u like
Sent from my DROID2 using Tapatalk
throttle body should be the same diameter, maf should be the same. the weapon r is your best bet.
Balls...forgot to mention that weapon r! Hahaha had it on my old 2.0 and loved it...you can also kinda convert to a cold air too.lol steph don't u have that too?
yes, it has the ram air kit which converts into a cold air intake of sorts. its the one i currently have.
theres already an SRI for the versa. the Takeda Intake
