Hey. So I've done MAD searching. So please dont get upset. I've scrolled through EVERY post regarding swc and google searched a thousand different wordings of my question to no avail.
I got the base model right. The 1.6 S Versa. Basic basic radio.
Successful replacement to a bada** headunit I am super proud of. And speakers. But check it out.
The base radio has 3 connections right.
20-pin main plug
2-pin FM plug
16-pin (swc/bluetooth?) I think, only because I found several posts on this forum backing up that information.
I'm trying to hook up the ASWC-1 which I'm sure I can take care of on my own ( but if you know the exact 3 pins/wires to plug into the aswc-1 from this 16-pin base model plug then you might as well let me know also, that would be awesome)
But my MAIN QUESTION
and it's not even a hard one.
WHERE THE HELL DO THEY SALE A FEMALE HARNESS ADAPTER FOR THIS 16 PIN CONNECTOR SO I DONT HAVE TO (actually refuse to) SPLICE INTO THE DAMN FACTORY WIRES.
please. Thanks.
Hers da foto brudduh.
Discussion Starter #4
CAN SOMEONE PLEASE SHINE SOME KNOWLEDGE AT ME. I even went as far as purchasing the 2015 nissan versa sedan 1.6 S FSM because the only ones listed on the nico website with the ones available for free download only went up to 2014.
So it said the same shit as the 2014 anyways.
20 pin connector has the fucking steeringwheelswitch A/B wires
A=pin 6
B=pin 16
Grnd=pin 15
12v accessory wire= pin 7
Tell me why the fuck my radio works just fine with the metra 70-7552 which has the red 12v accessory wire coming out of PIN 16.
(No 7, no 6, no 15)
And it functions just like the damn ignition. Turns on and off along with the key.
The manual is tweaking or I'm tweaking
Bro
What
The
Ruck
Someone help me
Who knows.
Who cares?
When you set down to do something that likely nobody else ever has you have picked yourself to be the test guinea pig there. I do wiring much more involved that that and I don't have a clue what you are even trying to do other than pointing out why this or that is what it is, and not going to do the research to write a 500 page book to explain to you what to do, what you are looking for there. It's not rocket science but you MUST know what each and every wire does there and in the other places where your wires originate as well, or a complete understanding of it ALL (not just 2 or 3 wires) to be absolutely sure you don't torch anything when you turn it on.
Modern cars have at least 5 miles of wire in them now, only the foolish make guesses anymore, you know the type, always looking for ECMs when they fry them, radios do the same thing easy as spit. The 2014 manual being the same as 2015 shows that if you had researched the '14 closer to find the same wire color codes and groupings you would have been able to predict the 2 manuals would be the same without buying the 2015 one. In fact you would not have even needed the '15 one at all. So you fell short there, I do that comparo all the time. Cars change occasionally ( like Versa '11 to '12 at model change) and the several years after the change will be virtually the same until they change things again to then do the same thing once more.
Did you bother to do wire color code interpretation there? Many plugins swear to work but they have mixed up color codes to make you determine pin position correctness when the code on pigtail does not match the car plug. I had to pull the pins and remount them all over the place in the last install I did using a Metra pigtail, it was totally miswired into the plug. One that was supposed to work. Then the other end got used with several wires of the wrong color code but you ignore the code to use the actual wire needed and why you have to know what all of them do to be complete and correct and not missing anything at the end of job before powering anything up. The wires do not care what color they are, only that they are in the right place. That install went up to work perfectly and several years ago and still works fine.
OP any luck here?
ASWC instructions say to connect pin 15 to ground. The diagram in the instructions say "Wire view of radio harness." The hell does this mean?
Me facing the connector means pin 15 is my rear speaker that I'm now having to ground.
And the connector facing away from me I'm not sure what the signal is on the radio as I can't find a diagram of the car radio connector.
