Hey guys, my SES light came on about a 1/4 mile after I filled up the tank. (Im at 53k miles)
Went and pulled the code P0171 - Fuel Injection System Too Lean Bank 1
-low fuel pressure
-Blocked injectors
-large vacuum leak
-MAF sensor fault
I couldn't find any vac leaks, the MAF is very clean, and I used injector cleaner 3 tanks ago. Re-did all the connections on the intake, and checked the exhaust for leaks.
The only symptom I get is a consistent high idle ~1000rpm, no loss in power, mileage is fine, starts up fine.
Any idea on what to check next? I don't really have the money to take it in.
Thanks for any input
-low fuel pressure
-Blocked injectors
-large vacuum leak
-MAF sensor fault
