ru reffering to my comment above and typing this?My V does this alot.... does anybody know what is going on?
Edit: my AC is not cycling. The V does this very often in warm temps, but also did it during the winter too.
AC compressor cycles with the heat on as well if it's set in the defrost position.My V does this alot.... does anybody know what is going on?
Very good call on this. Could be a motor or transmission mount.the contact of the engine with the body of the car under the battery my be worn out and cause this problem
I've had the hood vibrate when in drive with the foot on the brake before moving. You can turn the rubber knobs ( near the radiator ) to make the hood touch them or add round felt stick on shim that you use on the bottom of a chair. It worked for me. ( if that is where the vibration is coming from)the contact of the engine with the body of the car under the battery my be worn out and cause this problem
what what?I've had the hood vibrate when in drive with the foot on the brake before moving. You can turn the rubber knobs ( near the radiator ) to make the hood touch them or add round felt stick on shim that you use on the bottom of a chair. It worked for me. ( if that is where the vibration is coming from)
