I chopped the drivers side reverse light wires to see which was positive and I accidentally shorted the wires and now these don't work:
Electric Boot Release
Both Reverse lights
Horn beep and light flash when locking the car.
I am heading to the junkyard tomorrow, what should I get to try and solve the problems.
Good job there chopper.
Check your fuses, you've popped one. ONLY after securely fixing your little 'mod' there.
I checked all of the little fuses in both the fuse boxes and they were all fine. Would it be one of the bigger fuses?
There's a fuse box under the steering wheel to the left and also under the hood, on the right side of the engine. (on my 2012 versa hatchback). Did you check both locations?
