What is the purpose for this circuit? From what I can tell, it seems that you plug it into your sub outputs on your headunit and it lights up with the music? If I know what its supposed to do I might be able to help more.
yep! exactly. i tried it on my computer and it worked great. hooked up the power to the circuit in my car, and it no longer worked even though the audio was coming from my computer again. so yeah, its definitely the chassis ground. i just dont know why its the chassis ground or how it should be fixedWhat is the purpose for this circuit? From what I can tell, it seems that you plug it into your sub outputs on your headunit and it lights up with the music? If I know what its supposed to do I might be able to help more.
hmm i had a feeling of that. the circuit already works as is, with the ground connected to the audio ground and also the battery negative terminal, tested it before installation. But how can i accomplish that? the transistor utilizes the ground wire to finish continuity to the led circuit and what i am assuming is also establishing the audio ground as a reference voltage (?). the transistor needs to have a ground for the led circuit. can i just ignore the audio ground and maybe throw a capacitor in series with the mono audio to remove any dc bias and then rectify it?If you have it wired into a speaker wire or RCA output, you only need to use the corresponding negative terminal/wire to ground it.
