2009 Versa Hatchback.
I am about to replace the factory radio with aftermarket radio and have watched some YouTubes about how to do that and see that there might be a problem with the PASS AIR BAG indicator if I have to remove the wires from that indicator. In some cases it looks like one might be able to pop the whole indicator unit out without disconnecting the wires but maybe not.
I've read here that there is a procedure to reset that thing that seems to work most of the time.
I am wondering it I disconnect the battery before starting, and if I have to pull the wires from the PASS AIR BAG indicator, get everything put back together and reconnect the battery will that prevent the issue with the PASS AIR BAG indicator?
I would rather not have to go through the reset procedure if I don't have to although the reset instructions seem easy enough.
Disconnect the battery at least 5 minutes before you begin, and make sure the indicator is plugged in before reconnecting battery.
The reset procedure is easy. I have had to do it a time or 2 because I was an idiot.
I have not had enough time to work on this project yet - I want to plan for some things to go wrong and be sure I'm not riding around with a big hole in the dash...
I will disconnect the battery for a while beforehand.
Do you think that procedure might/will work or do you know that procedure will work?
If you know that procedure will work how can it be you would have to do it a time or 2 already (so I don't have the same issue).
It will work.
I was an ID10T. Doing something minor, disconnected light, but not battery. Turn key on with light disconnected.........That is how I know it works!
