Hello all,
my steering wheel no longer locks on my car and the key will no longer turn in my ignition. I have a 2011 versa s 1.8. I only have one key and my mechanic is suggesting I get a second key made from the dealer as they have the key code and I can get one made and programmed. They believe this may be the best first step... my thoughts however is if the steering wheel won't lock I still will not be able to get the key to turn...
Any insight anyone can provide would be greatly appreciated.
Hello all,
Take a look and see if this helps you work through the problem.............Good luck!!!!
https://www.wikihow.com/Fix-an-Ignition-Key-That-Doesn't-Turn
