1 - 11 of 11 Posts
Hello, and when i turn the key to the on position, the check engine light flashes 5 times and then goes away. Any idea?
Discussion Starter #2
Please help. the check is lit continuously. what needs to be done to solve the problem. no dealer nearby
Does the car start and drive?
Is there any codes in the car's computer?
[QUOTE = "scarecrowdjinn, post: 290765, member: 60160"]
Машина заводится и едет?
Есть ли коды в компьютере автомобиля?
[/ QUOTE]
код P2097
код удален, проверка продолжает мигать
User: 2016Versa posted a great article, I suggest you read as much as you can on the code.
I would have the code reset first, and see if the flashing and the code stay off.
The reset will probably not work, so here are the possible failed parts from the article listed above.
Possible causes for this engine code include:
Faulty catalytic converter
A faulty mass air flow or manifold air pressure sensor
Defective O2 sensor/s
Burnt, chafed, broken, or disconnected wiring and/or connectors
Engine exhaust leaks
Discussion Starter #10
reset the code P2097. the check continues to blink. the manual says that it did not pass Readiness for inspection / maintenance (I / M) http://www.nissaguide.com/nicon-2375.html while performing the described actions, the check caught fire again
1 - 11 of 11 Posts
