you have the new sedan right that's has the 1.6 in it I haven't heard of them going bad that's interesting I'd take it to the dealer
Ive got a 2012 S model with CVT and changed my oil a couple days ago with 1,200 miles on it to also get the breaking in stuff out. I also noticed a bit of ticking after doing so. Seems to be random. I used 5w-30 Peak oil.I've got the same issue. It does sound like the timing chain. I wonder if the HR16DE is equipped with a variable displacement (low pressure at low rpms) oil pump. This may cause the timing chain tensioner to not be as effective in controlling the timing chain slack on the chains departure from the crank sprocket. I currently have 1100 miles on my car and dumped the factory fill oil in favor of some Mobil1 0w-30 at 1000 miles to get some of the break-in materials out. I have noticed the ticking is slightly more audible with this oil. I don't have a tach but it goes away entirely at part throttle, i would guess 1750-2000 rpm. If anyone else has this "issue" please share, especially if you are a Nissan service tech.
I agree, it sounds like valve tapping.On the 07's it would most likely be valve tapping or a piston slap condition those are the two most common tapping locations on the 1.8L.
My 08 has had this condition since 15k miles on it and now I have over 107k on it now and running strong.
At 5600 miles, my engine made a ticking sound too. Tech said it was a normal injector pulse sound. Well, at 34000 miles, the sound is as loud as yours, and when put into gear it gets louder. Car is scheduled to go into the dealer Tuesday, and it will be diagnosed again. I too know that this sound is either a piston slap, wrist pin problem, or connecting rod bearing. The power train warranty is still in effect, and I expect them to honor it. If it was an normal injector sound, it would not have gotten louder over the years, but stayed the same. Hope the dealership does the right thing, but if not, I will take legal action if they try to fluff it off.Mine started @10k. Dealership told me it is the abs pump or injectors. I've built and blown enough motors to know when I hear a bad journal bearing. Its now @14k and going back for the same issue. Florida has a wonderful 3 strikes lemon law.
