My wife blew a tire out, and I had a spare set of rims from my 99 G20. Unfortunately, they don't fit on the front due to to caliper rubbing (they are 15"s)
Odd that the fronts didn't clear. I thought the front brakes on the Versa would be just about the same as the p11. They both use the same size rotor.Ha, I knew you'd like it. Unfortunately the fronts don't work or I'd have my wife rock 'em full time.
It wasn't by much, probably a couple of mm's. They spun fine when I test fitted them, but when I tightened them down it rubbed. If you look at the spoke, it is actually pretty shallow. Like someone else said, a spacer would probably get them to work well.Odd that the fronts didn't clear. I thought the front brakes on the Versa would be just about the same as the p11. They both use the same size rotor.
BTW for anyone that doesn't know a P11 is an infinti g20. Alot of other nissan crowds refer to their cars by chassis code. We could be C11 over here on this site.
Boise, IDoh by the way welcome to the forums! where in this crazy world do you live at?
You were exactly right. I had some 5mm spacers and threw them on the front. Perfect fit. I'll have pics up tomorrow since I just finished.what are the offsets of the G20 rims? you could probably use spacers
