tiida ABS
3355 Views 11 Replies 5 Participants Last post by  tida2007
HI THERE
HOW TO cancel ABS System on tiida 2007 ?
and start the car without it .
1 - 12 of 12 Posts
or if can cancel the Security indicator light system 2?
or how to restart it
1st off why would you want to do that?
I think the ABS can be disabled by Removing the fuse to it. (That is how I Disabled my old Almera's ABS accedentally the one time).
because im sick with it
i swap m car from manual to automatic full swap with wiring and cpus padals ele...
but the car won't start no lights in dash only the Security indicator light system flashing with or without the key
if i turn on the key i just hear the fan sounds only not crank and nothing:frown
all the fusee and relays are fine and good !!!!!!!!!!!!!!
Did you remember the Neutral Safety Switch? and to remove or fix the clutch switch?!
Manual to auto swap? Why? Are they all manual there, and it's the reverse (automatic is cooler than manual)?
has the immobilizer circuit been coded properly? your starting issue isnt with the ABS. ABS will not stop the car from cranking.
The "fan sound" is likely the fuel pump priming. Are all computers (ECM, TCM, BCM-if present) from the same vehicle, along with the key? If not, the immobilizer circuit will trigger.
Or you have a wiring issue, as Subtle is suggesting, probably in the gear selector, but it could be anywhere.
all computers from the same car
i add the automatic cpu only from anther car .and the key is working fine locking and unlocking the car
the problem is the Gauge Cluster not showing nothing only that Security indicator light system flashing with or without the key
,it was showing then i unplug and plug the FRONT CENTER AIR BAG CRASH ZONE SENSOR while the battery is connected and then its gone
+ sure not crank
2-wiring are fine and ok
if the immobilizer things how to get the CODE coz i have the immobilizer programer but i cant get the CODE Free?
wow . . . the the Gauge Cluster is showing now after fixing different inside wiring
but the Security indicator light system is still flashing over there
so
so maybe it will work
thANKS
If you added a TCM, then no, not all computers are from the same car. The immobilizer coding has to come from corporate through a dealer. THis is an anti-theft protection circuit, if you could get the code by googling, it would be pretty piss poor.
Some tuner shops may be able to disable the circuit, or code it out of the ECM. I know at least that is the common practice for VW/Audi tuners; they just go into the ECM programming remove the IMMO software.
I know folks here that have gone auto to manual, have to go to the dealer to get the ECM recoded.
what if the obd
what if the obd plug is not woring in the car ??????
and the windows not working ????
and the car lock
only i can lock and open from the remote .
1 - 12 of 12 Posts
