Do you guys rotate your tires? If so at what interval and which pattern do you rotate? Also for the DIYer's what is your method?
I'm thinking jack the car up from the front and lower on jack stands. Remove both tires and jack the car up from the back and remove both rear tires. Then put them in correct spots right? Is there a jacking point on the Versa in the middle of the car to raise both front or both rear tires at the same time?
Nissan is recommending every 7500 miles rotation. Dam seems like alot of work. I need an electric impact.
