Toggle switch?
1K views 4 replies 5 participants last post by  amc49
#1 ·
2011 versa. All my lights work except my tail lights. Bulbs are good. Fuse is good. Factory audio system has been removed. No radio atm. Where do I start?
#3 · (Edited)
There is a fuse in the IPDM box (white box with black cover by battery) under the hood. The fuse is marked tail and right about in the middle.
This fuse also powers the dash lights except the cluster as well.
By not having the radio, the circut is detecting an improper load and blowing.
#4 ·
Welcome Chiefr,
When you say tail light, you mean the lights that come with your headlights? or do you mean the brake lights? or do you mean both?
#5 · (Edited)
'By not having the radio, the circut is detecting an improper load and blowing.'
It would be highly irregular for that to happen, fuses just don't do that. Power not used loads nothing at all, or the battery itself would blow out.
Improper load is too much, too little does nothing. Look at fusebox setup, much bigger fuses are ahead of the much smaller ones in a same circuit and they don't blow do they?
If BRAKE lights are out start at the stoplight switch.
only too well.
