For those of you that have gotten aftermarket wheels, did you just use your factory sensor, or did you get new ones with the wheels? Since I live in the North, I've considered getting a set of rims and mounting summer tires on them, then using the factory ones for winter tires. However, with this, I would need to get 4 more TPMS sensors, and, from Nissan, the sensors are $120 each.
Also, CarID has these sensors. Has anyone used these, and, if so, are they the same as the factory ones, and will just need to be set to the correct frequency, or is there more that will need to be done to the car to get them to work?
