1 - 1 of 1 Posts
I recently replaced the torque converter seal in my 07 versa.
After a 10 mile test drive i noticed it was leaking again.
I removed the motor and transmission together out the bottom- pretty lengthly process and im not thrilled to have to go through it again.
The transmission shifts fine and operates smoothly.
Im really thinking about just buying a salvage transmission for my next go around.
Im guessing the input shaft bearing is bad causing excessive play in the torque converter wiping out the seal.
I cant find a single problem like this on the web involving the versa 4 spd trans.
If anyone has any insight as to what might be causing this problem im open tosuggestions.
1 - 1 of 1 Posts
