Hi All!
I have a 2013 Versa with the manual transmission. I recently replaced the front wheel bearing, control arms, shocks/struts, breaks and rotors. Took is for a test drive and noticed a new sound. After doing some poking and prodding I think the Trans-axle bearing is going up. ( I get some up and down play when I try and move the axle at the point it goes in to the transmission).
Has anyone encountered this issue?
Were you able to replace the bearing or did the transmission need to be rebuilt or replaced?
Is it possible it is not that bearing?
Any thoughts are appreciated
Thanks!
Thanks!
